Can i lower the volume of Accenta+ alarm keypad?
11 Jun 2012
Hi, does anyone know if i can lower the volume of Accenta+ alarm keypad?
With having a young child i was hoping there may be a way to lower the volume, mainly so that when we set it going to bed, the beeps won't wake the baby at all.
We have noticed she does move around a little when we are putting it on as her room is just up the stairs from where the keypad is.
James
Check the manual for the system you have along with the keypad you have, models do vary, take a picture of the PCB.
Off the top of my head i don't know, but don't ever remember adjusting the volume via programming so its likely to be a pot on the PCB to adjust if at all but there are many different models about.
Program it for silent set for part ....or stick some tape over the piezo inside the keypad...are you sure it’s not coming from the panel speaker ?
do you which panels support the silent part set, fairly sure some of the older ones don't, although most will take the keypad.
