My Honeywell 2 port (normally closed) V4043H is nackered and approx 20 years old. Not sure if its the head or the paddle. Lever a bit stiff and slow to return. Heating is coming on when it shouldn't.
However, there is no way I can get a spanner on the valves 22mm nuts as there are other pipes really close either side. Also the pipes go into concrete, so little play/ movement in pipes to get the valve out.
Can I remove the head and the paddle plate from the old one, and put new ones from a new valve on? Are the parts interchangeable, 20 years apart? All looks the same.
