Hi I am looking to upgrade our Drayton Digistat 1 thermostat with the Drayton Wiser Thermostat 1 kit but want to check wiring for the Heat Hub if anyone can help.
So existing digistat is battery powered and has three wires for three connection prongs as follows.-
Red into terminal 1 - which I believe is the common C
Blue into terminal 2 - which I believe is the heating off (heating satisfied)
Yellow into terminal 3 - which I believe is the heating on (call for heat)
I have no fused spur to the thermostat.
The backing plate on the current digistat is a little larger than the new one for the Heat hub so I will need to rewire. Am I safe to wire the new plate back in the same config as above mindful that the new plate has 6 positions?:-
N
L
1 - Com
2 - Off
3 - On
4 - ON although should be redundant in my case I only have a 1 channel hub.
I can find plenty of info on how to upgrade a two wire battery thermostat and a 4 wire powered thermostat, but not a three wire existing battery thermostat.
Advise please
N
L
1 - Com
2 - Off
3 - On
Advise please
