Can I use blocks for sleeper walls?
13 Sep 2010
Hull
Hi all
I have a concrete sub-floor onto which I am building some sleeper walls to support a pan and joists.
Can I use blocks rather than brick? They are not very high maybe 200mm.
If so what type of blocks should I use? do they need to be the high density concrete ones?
It will just be quicker and cheaper to use blocks
Thanks for any advice
Matt Houldsworth
Blocks and a wall plate are going to be higher than 200mm, so by the time you have cut them, it will be quicker to use bricks - and remember to honeycomb the wall
