I assumed from your description that the existing drilled holes would line up with the 44mm backseat, leaving a half gap at tne back, and maybe extra height of the new lock to be chiselled out
The height of the case is 90mm, which is more than 3 inches, so you would have some chiselling to enlarge the mortice. The Chubb 3G114 is 76mm high and 67mm deep, which would fit, but the backset is only 40mm, which is a little less than you want.
I can't see the thickness of the case mentioned. It nay be about 18mm. Old internal locks are usually less.
