Can only get 1/4 inch of new key in lock from outside
31 Jul 2008
Cumbria
Just had new keys cut, the new one will only go into the lock from the outside 1/4 of an inch, it works fine from the inside.
The old key works inside and out.
UPVC Door - eurolock
Has anyone any ideas what's happened?
heeelllooo lifesaver and welcome :D :D :D :D
no key on the other side!!!
trying same key both sides one side then the other in succetion!!!
try cleaning any burr with a wire brush
try old keys after the new key to rule out a lock problem
try moving handles and oiling mechanism including oiling keys before insertion :D :D :D :D
a very small squirt of wd40 into the outside cylinder should cure the problem,its probably a bit dry and the new key will be not be as worn as the original and wont slide in as easily.
Hello Everyone - and thanks for the welcome. What a fantastic website!
Unfortunately my 'old' key is now 90 miles away with my son who is on holiday for 2 weeks, I locked the door with the old one and handed it to him, safe in the knowledge that the new key worked in the inside so it was ok - that'll teach me!
First thing I tried was the WD40, followed by silicone spray to no avail, I'll have another go today, and will try the oil trick.
At least I can lock myself in! :roll:
