I've always just assumed that the colder the return to the boiler the more efficient the boiler would be (i.e. greater differential so heat transfer through manifold is faster).
But I've come across direct evidence to the contrary (e.g. boiler recommends minimum 60 degree return, 'hearth' temp is less than 85 - I guess that is flow temperature)
Can someone explain to me what happens when the return is low or high and how the boiler copes with this? I can't seem to google an explanation why a high return temp would be beneficial. Also, can this be countered i.e. divert some of the boiler flow back into the return to keep the temperature optimal?
Specifically, I'm trying to use a domestic Kerosene boiler to heat a swimming pool which will remove almost all of the heat from system.
