Can someone give me the 'nod'?
Some - quite a lot - of thermal store systems end up leaking due to inadequate corrosion inhibitor having been used. That has given them a bad name. Also, the Heat Bank variety will have to have limescale removed from its heat exchanger, probably every several years. Not a huge job if it's plumbed in with proper valves. Coil-in tank "Thermal Store" ones aren't so susceptible. Both types seem to be used mostly in New Builds, I've seen several 20+ year old ones untouched and working fine.
It's just one of a number of options (as you've found).
Stick a query on Screwfix and we'll all have fun reading the replies. :twisted:
Remember that whatever the "best" solution, if you can't get someone to install, understand or maintain it, you'll regret it!
Thermal Store...........80`s estate c.100 houses.......hard water area.......all gradually being replaced...... because they are leaking ,visibly to the outside under the foam insulation.....(by combis)........not by me , I`m not CORGI :cry: .............Hope this helps your decision :wink:
