Can the Pyronix Euro46 Email Out?
26 Mar 2011
Aberdeen
I have the Euro46 App Panel and App Notifications are working just fine.
However, I have a "smart home" and previously, I had certain things programmed to switch off once the alarm was set. This was driven by the receipt of an email however.
Can the Euro46 trigger an email on set/unset/alarm?
You can get push notifications for alarm,arm and disarm. These need to be selected in notifications in the cloud account.
I don't believe it does do direct email notifications, you could use the programmable outputs so if your smart home system as any sort of input unit that could work. The other way is if you have a CCTV dvr/nvr system with alarm inputs that will more than likely have a email function.
Thanks folks.
App Notifications are no good in this instance, I want to utilise the receipt of an email to trigger smart home actions.
Both my Smart Home setup and CCTV setup run on Linux, and have no physical IO. So short of writing some code to read the alarm output I'm a bit stuck.
I previously had my "Night Set" mode turn lights off etc... I'll probably just opt for a big red button next to my bed to do the same.
