Hey, I have a gas supply in my property with no meter. Im going to get central heating fitted and I was wondering if I could connect to the supply with out getting a meter fitted?
Average temperatures in the Bahamas range from 80 to 90 degrees Fahrenheit (27 to 32 degrees Celsius) in the summer to 70 to 80 degrees Fahrenheit (21 to 27 degrees Celsius) in the winter.
of course it can be done
just put a clamp on the rubber pipe to restrict the gas flow
you may have to balance the temp of your hot water with the central heating tho
