Can this wire be used for a new light?
27 Sep 2011
A cupboard in my bedroom used to house a water tank
Following removal of the tank, I would like to use the empty space as a wardrobe.
Currently, the cupboard space has a redundant switch with a fuse.
After removing the switch, the wire used is 1mm two core and earth.
I also know that the switch is on a separate curcuit on my consumer unit and in terms of overcurrent protective devices the amp rating is 6
What I wanted to know is whether i could
1. Replace this fused switch with a regular switch
2. Install a downlight in this area?
What capacity is the fuse in the fcu?
Blup
^^^What he said^^^.
Look at all your other breakers for lighting. Chances are they're 6A too.
To install the downlight can i
1. Remove the cable that goes into the existing switch.
2. Extend this cable up to the light fitting
3. Connecting the red wire to COM and black to neutral
4. Then run a fresh piece of 1mm cable from the light fitting back to the switch?
Would this be okay? Could i simplyfy this in any way?
COM is usually found on a switch.
What you are describing is looping this in at the light.
I would swop the existing switch for a light switch, and run a cable from there to the light. Then the loop in is at the switch. Easier for downlights - these do not have support for loopp in wiring, you would need to add a jb at the light point, you don't need to do this if you loop at the switch.
Just want to check i have this right before wiring
The wire which goes into the switch is the old red/black colours
So, i plan to connect
Red = com
Black to L1
Then i will use a fresh piece of wire going from the switch to the downlight connecting aa follows
At the switch
Brown = com
Blue = L1
Then at the downlight
Neutral = blue
Live = brown
Does this sound correct? Or will things go belly up?
:eek::eek:If you do that, when you operate the switch, the fuse will blow and you will probably kill the switch.:eek::eek:
Red to COM
New cable brown to L1
Put the black and new cable blue wires together in a piece of insulated terminal block
You'll then have two earth wires. These need to be sleeved (yellow and green) and also terminated together in a separate piece of insulated terminal block
at the downlight
Neutral = blue
Live = brown
Earth to earth terminal if the downlight has one.
