Thanks Dan.
Ive already bought a standard honeywell 2 port valve. Will it not work with this?
If the 2 port value is in the loft where the boiler is and the ufh manifold is on the ground floor is it permissible to extend the zone value cable via a junction box to the manifold where its wiring centre will be? Or is there a limit in terms of cable run length?
