can we tile over an area of rising damp?
3 Aug 2008
Lancashire
we removed a solid fuel-burning boiler and exposed the chimney breast - this area has had constant heat for 30+ yrs
now we notice rising damp
my mother is in her eighties and can't face "mess" - like putting in a new damp course
could we just tile over it and hide the problem? Plaster is "sound" at present -just stained by damp?
If there's damp there then the tiles will just fall off again.
What makes you say that?
I think I see why you're asking - what I wrote was ambiguous.
What I mean by "damp" is recurring damp, not a lickle bit of moisture that would soon wick away in the general drying out process in the days after tiling.
I would agree with you if we were talking about tub mixed adhesive, but if using a powdered cement based adhesive, why would you suggest that the tiles would come off?
thanks for your comments
presumably a competent tiler would know what mix to use
Fair play gcol - you're absolutely right. I was being very lazy, and assumed from the OP that he himself would be doing the tiling, and jumped to the conclusion that he would premix. :oops:
I should have said...
If you do go ahead and tile before curing the damp problem, then ensure you use a powdered cement-based adhesive, as the premixed types will deteriorate if persistently dampened.
Notwithstanding that, you should address the cause of the damp anyway, because the water has to go somewhere and it won't do your mother's house any good.
.... you should address the cause of the damp anyway, because the water has to go somewhere and it won't do your mother's house any good.
Yes you should. If the wall is damp, the adhesive and grout will be damp too. Damp grout = mouldy grout. However, it will be limited and it won't look as bad as a mouldy wall.
thanks for taking the trouble to contribute to this discussion - I know we should address the issue of damp - but was hoping to do it with minimum disruption- sort of knew all along this wasn't the best option to tile
there is a chance the damp came from a slight leak at the boiler pipework.
can you post a pic of the damp pattern on that wall and the ones around it?
