Can you cause damage by adding too much sludge remover?
8 Nov 2004
Guys
A simple question. :shock:
Can you cause much damage from adding too much sludge remover?
I added some (can't remember the type, got it from B&Q, small triangular bottle - something"Restorer"), then someone recommended to me some Sentinel X400 as being much better.
So I want to drain my system (old stuff only in their for 3 days) and add the X400 via F&E tank instead.
Apart from perhaps exposing some corrosion masked leaks, can I do my system damage by overdosing a bit on the sludge-caner?
Ta
PS Edited to add detail in case necessary:
Low water content, gravity fed
Thorn Apollo boiler
Potterton Ep2000 timer
new immersion element, new pump, new 3way valve, 5 rads over 2 floors
a simple question with a simple answer!
if only it was always like that..
Kevplumb - thanks again for your help. :wink:
