You don't necessarily have to wait for the cheap-rate hours. If you run the machine in the evening, there should (if the water-heating setup is 'adequate') still be a reasonable amount of fairly hot water left for the machine, and then the cylinder will get heated up again when the cheap lecky starts.So at long as you set the DW off at night, when there is plentiful HW then that is fine. (you don't want it using HW you could use for other things).
With many/most modern machines, one cannot get them to start by using a time switch in the electricity supply - I presume for 'safety' reasons **, many/most seem to now require that one presses a button to start them.But of course you could just set the DW off at night (connected to the cold supply) and that may even be slightly more efficient! But you would need timer you trusted to cope with the 13A load
** seemingly a bit daft, because many of them have built-in 'delayed start!
Kind Regards, John
