Can you fit a power shower to a main multi point ?
29 Jun 2006
Lancashire
Tittle asks the question,
Can a power shower be used with a main multi point boiler ?
There was an old triton pumped shower fitted before i ripped out the bathroom ( the one with the small pump housed on the wall unit)
but I always thought you couldnt run a power shower off a multipont ?
:D
Gets even better :D
Never knew that one. don't know how the boiler wasn't damaged if he was trying to pull water faster than it could heat it.
The flow would have been restricted/determined in the multipoint. Those little pumps would only supply about 10 litres/minute anyway, so probably did absolutely nothing in yer man's case.
I think they're unavailable now, by the way, which is a real shame. I'm looking for a working "scrap" one....
kevplumb said:
water regs marra
yer can't pump a mains supply :wink:
To be strictly accurate (;)), you can pump a mains supply if the flow rate is no more than 0.2 litres/minute - above that you need the permission of the water supplier, which is unlikely to be granted.
Softus said:
kevplumb said:
water regs marra
0.2 litres/second ... 12 litres/minute
Er, yes; as I said, to be strictly accurate... :oops:
Do I really have to spell it out?
Did you not notice the 'embarrassed' emoticon?
Just waiting for you to return the favour next time I make a mistake (which happens quite often...)
Come on Guy's,
No need to fall out.
I only asked a simple question. Anyway, I fitted the new Thermostatic shower today and to be honest, there is no need for a pump.
Its works fine so no need to fall out now :)
Chris,
If i knew you wanted the old one i would have posted it to you, In the skip now BUT i am fitting a new shower next week that had a gravity fed power shower (Mira but a slightly more modern one)
She has had a new combi fitted and the plumber has issolated this one so it will be coming out next week if you want it.
