Can You Get Bar Mixer Shower With 15mm Inlet Connections?
15 Dec 2007
Bristol
Long story, so I won't bore you. Just trying to sort someone else's problem job.
Do any bar mixers come with 15mm compr. inlets, instead of the usual 3/4'' BSP? I know many big chunky (expensive) mixers do.
Need to attach one to 2 short lengths of pipe that have 15mm nut and olives on, that stick out of wall. The wall has been newly tiled.
Alternatively, can you buy a chrome fitting thats 15mm compr. one end, and 3/4'' male thread the other?
Otherwise, will have to hack out new tiles. :cry:
you can buy a 3/4" male iron to 15mm copper compression fitting , but it will make the shower a couple of inch's off the wall.
Thanks, that's a good suggestion. The previous plumber left it with a washing machine valve (15mmx3/4'' male), so its way off the wall anyway.
Your suggestion prompted me to search, and BES do a chrome 15mm comp. x 1/2'' male fitting. They also do a 1/2'' x 3/4'' chrome bush that will go on the end of this fitting, so I can screw shower onto this.
Forget about the bar shower. If you are skint get a Trevi ctv, cheap as chips.
Yes but your valve will be 4" out from the wall :shock: and the pipes will break the first time the kids have a swing from it :lol:
A bit more of an eyesore than a "big chunky mixer"
You(or your "plumber") should really have thought of this before you tiled.
