Can you replace an integrated dishwasher with 'normal' dishwasher
13 Feb 2006
Tyne and Wear
I have a rental property, which was previously our home.
It had an integrated dishwasher, which seems to me, just a dishwasher with a matching cabinet door screwed to the front.
Anyway, this dishwasher is no longer working, but getting a new replacement door may be a problem, so I was thinking, would a 'normal' non-integrated dishwasher be OK, to fit in the space.
thank you
Yes, a 'normal' one should fit in the space but why not fit the door from the old dishwasher onto the new one? They don’t come with doors fitted.
Free standing dishwasher normally needs 600mm+ space while integrated fits in a 600mm space including carcass.So will be a tight fit.
A "normal" dishwasher might not have adjustment to counterweight the additional load of the decor panel.
I'm sure you don't really mean swapping the actual doors over.
I meant why not buy another integrated dishwasher and fit the door from your old non-working one onto the new one. I got the impression that the OP was concerned that they wouldn’t be able to get a new door to match the existing cupboard fronts if they bought another integrated dishwasher.
Looking online, all integrated dishwashers are 59.8cm wide. Many freestanding ones are 60cm but there are others that are 59.8cm and some are even 59.6cm presumably to fit inside a 60cm space?
Depends on what the OP wants I suppose - they could replace it with either.
No fitting required for this "normal" dishwasher.
Stand alone dishwashers tend to be cheaper than integrated, so maybe if the OP is not fussed over the look of the door, then it is a case of why pay more.
OP have you measured the space? Is the existing washer inside a carcass or is there end panels that could be removed?
Ao have a baumatic integrated dishwasher for not much more than the cheapest freestanding one.
