can you run a machine on cold fill only
27 Nov 2006
Surrey
i have a hotpoint wf840
can i run it on cold only
but without damaging anything on the machine
i will have the hot fill tap capped
can't see anything in the manual that says i can
i feel i'm asking a silly question but answers are very easy when you know the answer
yes it will work ok but will take longer to do a wash as it heats the water but you need to fit a "Y" and connect both hot and cold connections to your cold supply if it has a hot connection (modern ones tend to be cold only)
thanks for that kevindgas
but if i feed both hot and cold into the cold my clothes will rinse in a warmer water and that is surely wrong
i,m suggesting just cold feed from mains to macines cold feed & capping off the hot feed
sorry if i wasn't clear
no you got the "Y" the wrong way!
cold main into "y"
2 pipes from "y" to hot and cold connections on washing machine as the machine would normally take hot water on some programmes and will stall if it cant get water (but it can't tell between hot and cold temp - it just raises it until it gets to right temp)
