- Joined
- 9 Sep 2012
- Messages
- 2
- Reaction score
- 0
- Country
I seem to have a new problem with my 2 year-old dishwasher
All has been fine until today, when in the middle of a wash I heard a loud vibration in the middle of the cycle. This now seems to be there for good. The noise sounds like a pulsing 'bashing' of water against the inside of the front door and is almost like the noise a tap makes when there is an airlock in the pipe, but I suspect this is just resonating from the actual source, wherever that is.
Some diagnostics, done on a cold rinse cycle:
1. Took out all trays and rotating arms.
2. Checked and cleaned filters.
3. Washer starts and sound of filling can be heard
4. Washer clicks into next phase and vibration begins and continues throughout.
5. Washer clicks into drainage cycle and drains without problem.
6. Cycle finishes, apparently all okay (except for the vibration).
Now, I don't know how these things actually work, under the skin. I presume it fills some vessel within itself at first (to allow heating for hot programs), and that pump seems to be okay. I also assume that there's another pump that pumps the water out at the end, and that too seems to be okay. But what happens in the middle? Is there a 3rd pump that cycles the water around during the wash? I'm guessing that there is, and that the impeller on it has become imbalanced - maybe a blade has broken off or something.
Any suggestions as to what could be going on and what I might be able to do about it would be most welcome. Even a pointer to a service manual that shows all the components would help...
