Hi
I have the above machine and it recently through a spanner and refused to finish a cycle and kept giving me code 9 which i found to mean ( electronic control module fault)..
When i checked the module i found the circuit board was burnt out in the centre and ruined so i replaced it with another thinking that was the end of that!! Wrong!! Then it showed error 5 ( fault on wiring of heat sensor or faulty thermostat) . Checking the wiring i found a fair bit of it was showing heat damage so i then replaced the whole wiring loom which was quite a mission and thought that was the end of it Wrong again!! Now its not showing the fault 5 but again showing the fault 9 around 20 mins into the cycle like it did in the beginning !! I have checked the module again and all seems ok with no signs of damage???? Seems odd that after replacing the module and even the whole loom im still getting the same fault?? Wondered if anyone could shed some light on this as im out of ideas here tbh.. Almost got a new machine here and my misses is needing it working asap lol
