    Dismiss Notice
Cannon C60ETX Cooker Problem
Discussion in 'Appliances' started by izzybella, 11 Jun 2015.
  1. izzybella
    izzybella
    11 Jun 2015
    Thanks Received:
    Leicestershire
    Country:
    The display and ovens have stopped working, although all the rings on the hob are still working?
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    A lot of ovens will not work unless the timer controller is set.
    As your display seems to have power-loss, it would suggest you either have a loose connection in the circuitry to the control panel or the panel is faulty and require replacement.
    On occasions and always worth a punt, if you turn the power off to the appliance, leave a short while and turn back on, it may energise.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
