Cannot Change Lightbulb - B22 Hanging Fitting
27 Oct 2011
London
We have a light fitting similar to the one pictured. I think it is a B22 fitting.
I have gone to replace the cfl light bulb but cannot align the pins on the bulb. Seems fitting is damaged or maybe I am using wrong bulb? Note we have an identical fitting in another room - so think it is an issue with fitting.
Is there a safe way to bend fitting back into place? Or can part be replaced without an electrician?
Pretty sure previous owner forced wrong bulb into fitting...
Check new and old bulb.
Does one have 2 pins and other 3
That's a good point. The existing bulb never sat properly in socket. The socket appears to have groves for three pins.
I assume a two pin bulb cannot fit into a three pin socket because pin alignment is different?
Think that answers the question. It must be a bc3 fitting and needs a three pin bulb.
Can I change the fitting myself? All other fittings in the house are two pin.
