Hi!
I have gravity-based open system with Baxi boiler and Myson pump (about 7 years old). System supports 8 radiators.
I need to drain down and Fernox system to clear sludge and hydrogen build up. However, I can't locate the drain tap. There isn't one on any of the downstairs radiators which is where I would usually expect to find it. There is a spring loaded knob just above boiler which releases water into overflow pipe but I believe this will only clear water out of the radiators upstairs.
Any ideas? Could I drain the entire system any other way?
Many thanks for your time.
