Can't find radiators in my size!
15 Jan 2004
I've been looking around to replace a couple of radiators but I can't find the correct sizes. My bedroom rad is 600mm high and 960mm long. I can only find 900 or 1000mm rads. The living room rad is 350mm high and 1850mm long. I can't find anything close to that length.
Can anyone suggest a supplier/solution? I don't want to move the pipes or anything.
Cheers.
if you can not find one the size you require then i can only suggest you get one custom made, but that will probably cost more than moving the pipes
Try your local Plumbcentre....they are in the Yellow pages, they should be able to get you rads within 5mm difference. You could also use teloscopic radiator tails!
