Can't open airing cupboard door.
3 Nov 2009
Hi people.
My airing cupboard door won't open because a clothes horse is stuck under the handle on the inside (why there needs to be a handle on the inside I don't know, but that's the situation).
I've tried taking the outside handle off in an attempt to bring the spindle out from the inside handle, but they are attach with a grub screw!!!!!
I can't see that there is anything else I can do with the hinges either.
Any other suggestions? Maybe these pictures will inspire an idea or two....
http://www.flickr.com/photos/53910507@N04/sets/72157625709917673/
Thanks for any help offered,
ETFairfax[/quote]
try string and a piece of wire.
bend the wire into a U shape and tie the string to one end, feed it around the latch till you can grab both ends of the string and give it a pull.
hopefully that will open the door...
With the external handle off, bang the spindle to knock it and the internal handle off the door
Then fit a ball latch instead
Metal ruler, hammer it down the side by the latch to release catch.
Failing that cut off top or bottom of hinge pin with a hacksaw and tap out hinge pins.
