I took off bedroom radiator to decorate - was rewarded by lots of water coming out of TRV, so had no alternative but to work quickly and get the pipe ends capped off as quickly as possible.
I then forgot all about it until today, when I finally got around to thinking about putting the radiator back on. Of course, as soon as I loosen the pipe cap, I get water gushing out exactly as before (only this time it's messing up my newly painted walls so I'm even less relaxed about it).
The TRV is a Pegler Terrier, and only about 5 years old, so I'd hope its working fine. The valve settings go down to "0" which I understand is supposed to be fully closed.
I've tried swapping the TRV head with one from another radiator, I've also tried replacing the TRV head with a plastic decorators cap. None appear to push down the valve fully.
I can't think of any alternative now to draining down the system to get my radiator back on. Or am I missing something?
Should I assume the TRV is bust? I've heard of valves being stuck closed, but I would have thought stuck open is less likely? If if try pushing down the valve top with my thumb, I can feel it moving, so doesn't seem to be stuck.
Baffled.
Baffled.
