Capicator on riello burner
4 Feb 2016
Ireland
good evening ... Is a capicator on a Riello motor possible to work intermittent ........ Is a capicator , when not working , possible to work for say 3 times a day and then lock out burner ... I then press red button 5 to 10 times and it then may work for a week .. Then same again ... Thanks in advance for you're help
Hi ...thanks for your reply .. I haven't asked Riello, ... But I had a problem with a burner that was locking out intermittent and when I pressed red button sometimes it would run no problem and sometimes it would hum like the motor was stuck ..... I have replaced the capicator 3 weeks ago and have had no problem since .... Now I am starting to think I had a possible bad connection .... Or are there any other explanations ... I didn't remove burner and didn't remove pump .... Just whacked on the capicator in position ... Problem seems solved!!
