So lets say you were doing a re-wire and needed to chase out walls to run new cables, would you bother using capping over the new cables before plastering over the chase to fill it in, and if so, would you use plastic or metal capping?
I know that both plastic and metal capping provide no mechanical protection under BS7671 and are there just for the sake of the plastering process.
Another similar question is when fixing cables on internal brick walls, do you prefer galvanised banding, normal metallic cable clips or something else to fix the cable to the wall?
It seems like these type of questions can generate a lot of inconsistent answers and open a can of worms from looking online.
Regards: Elliott.
Regards: Elliott.
