Hello
I have recently fitted one of these thermostats to the boiler and in the main all is working ok however i am unsure as to how the boilers anologue clock should be set.
My assumption was that this would be disregarded/overridden by the stat, the switch has 3 settings , timed, continuous and off
I currently have the switch set to continuous so basically my question is what is the correct setting and if continuous will the stat override the clock ?
