Carpet Gripper
31 Oct 2007
Edinburgh
I am putting down carpet gripper to save time before the carpet fitter arrive friday morning. I want to fit some 30mm away from the skirting to run tv ariel and power etc. Will the fitters be ok with this? Also what is the optimum distance from skirting?
Thanks.
- leave it to the fitter - they all have different preferences, and in any case would normallky fit it tighter than you suggest. (having said that it is common for cables to run between gripper and skirts)
Oh and fitters shouldnt charge any extra to fit the gripper (up ere they dont anyhow)
Just ensure you dont fit the cable too tight!!!!
Can't agree more, whatever you do the fitter would have done it the other way, in my experience I believe it's more common for cables to run behind the gripper, often with a second row of gripper holding it in place and protecting it to some degree, just be aware that fitters WILL NOT run power leads under carpets, it's dangerous/lethal and likely to invalidate yours and their insurance should you have a fire. Aerial/cable leads and phone lines and speaker cables are less of an issue, but be prepared that if there are alot of cables, the visual appearance of the finish of the carpets in these areas will be affected and may limit the ability to stretch the carpet properly 1st time round.
Thanks guys, guess I will leave it to them. Just wanted to have everything ready to make it quicker for them and I could leave for work.
sorry have to disagree, cant see how you can turn a carpet down properly behind a gripper with a co-ax behind it and fitting a power cable here is not safe
