Hi
Can any of you tech guys help me with a problem on the above system?
I have installed the system and wired it up as a double pole set up as per the manual
the problem is that i cant for the life in me find any of the zones to program when i try and do a walk through test it doesn't show any of the pir's/door contacts in that test?
I have checked and double checked my wiring and its all fine there is power to the pirs and i have removed the link in the panel for double pole connections as per the manual.
The only thing i can think of is that its a programming issue on my part (the instructions are a bit sketchy to say the least)this is the 1st one of these ive installed and its a bit of a pain in the back side as a half day job is taken up 2 days now.
