catenary wire
15 May 2010
London
hello all does any one know any websites that show how to use the catenary wire fixings as i dont have a clue i dont intend to use it for any thing electrical at all
many thanks
OK.
Screw a hook in both ends of the run.
Fit the twisty turny thingy at one end
Attach one end of the catenary wire to the twisty turny thingy
Take the other end of the wire to the end of the run
Connect that end to the other twisty turny thingy
Hang it on the hook
Turn the twisty turny thingy until the catenary wire is tight enough
That's it.
PS. At some point you'll have to think about whatever it is you want to hang from the wire. Usually its best to fit that when the catenary wire is at ground level. Its more difficult 7 metres up over a busy road.
TTC
Yes, the real question is will you hook fixings be strog enough to hold the tension from the turnbuckle?
Try finding a friendly BT Installer and see if you can "borrow" a couple of Eyebolt 1A's, a couple of Clamps Dropwire and a suitable length of Dropwire No 10.
That will hold a good old weight before causing any problems. All you will need is an 8mm masonry bit for the eyebolts and a 10mm open ended spanner to tighten them into the wall. The dropwire wraps around the clamp once you've fitted it to the eyebolt ( very obvious to fit btw ) and I can guarantee it will NOT come out of the clamp. Make sure the wall you're fitting to is nice and solid though and if you can, drill the brick directly.
