Hi all,
Manufacturer is unable to explain the cause, so hopefully someone here can help me?
The lower part of my UPVC door panel (within the door and under glass) bowed inwards during one cold winter, then adjusted itself over warmer months - almost back to normal, but with a slight inward warp. The panel has now cracked in 4 'corners' above and below the letterbox area on the outside UPVC only - but the warping occurred in the decorative panel below this. It will be replaced under warranty.
The core material is double MDF and polystyrene (assuming they installed what I paid for).
A heater is the other side of the room, so it's not near any direct source of heat. Manufacturer is aware of woodgrain foil problems occurring in the summer and products have been improved, but is unable to explain why this has happened in winter and therefore give me any guarantee that it won't occur again!
Does anyone know why UPVC would warp like this in winter and then eventually crack?
