CCTV - advise required on setup
16 Sep 2010
Merseyside
Hello
I would like to replace my cheap setup with something that is half useful - current setup is rubbish an is hard to distinguish what the cameras record (joys of buying a "kit" from eBay)
I'm looking at Hikvision, as they seem to be recommended by loads of peeps? But there is literally hundreds of different DVRs & cameras available.
Im only looking for 3 channels as my house is tiny. I already have 6TB WD purple drives.
Help please
I upgraded from a cheap system to a hikvision 7608 NVR with 6 x DS-2CD2142FWD-I
While the initial spend was quite a bit I am very happy with the system.
You could go for a Hikvision Turbo DVR and Hikvision TVI cameras, you can use the existing co-ax and power cables and get 5MP.
I recently upgraded an aging system (700 TVL) with the above as it would have been a nightmare to rerun new cables, the results are superb.
DS-7204HUHI-K1 DVR about £100; DS-2CE56H1T-IT3 5 MP TVI camera about £55 each.
I'd definitely consider upgrading using Hikvison Turbo. Same if not better picture quality than IP and for almost half-price. IP cameras cost more but you will be paying for feature that you will probably never use.
cameras should be specified on what they need to do.
resolution/ field of view and height they are being installed at are the primary things to consider fit for the job. Then the size of the harddrive for recording.
Night time viewing is another important requirement, and that depends on how much light you have, HIK have EXIR which is certainly better over the spot LED IR.
