CCTV cameras
18 Aug 2011
Hi
Looking to get cctv for my house.
Iv seen these cameras:
http://www.cctvdirect.co.uk/products/Twilight-FLD-%2d-High-Resolution-700TVL-Vandal-IR-Dome.html
http://www.cctvdirect.co.uk/product...ra-Low-Light-%2d-Adjustable-4%2d9mm-Lens.html
http://www.cctvdirect.co.uk/product...2d-2.8%2d11mm--700TVL%2d-Ultra-Low-Light.html
Now not sure which ones to go for.
I want one at the top of the house monitoring the drive and another on the other side monitoring the front of the drive and partially street were car is parked.
Maximum distance is around 30m for the furthest view.
And around 5-10m from top of house to drive
Also want a camera to go next to door and cover front door.
Can someone suggest the right cameras for the job.
Also after a dvr with network support
Budget is around £400
Any suggestions?
Hi there,
we don't use this make of camera ourselves but 700tvl will give you a cleaner picture than a lower tvl.
When purchasing a dvr check whether it supports a dynamic ip address or if you have to download software to track your ip address. it can be a bit of a minefield your not good with IT (i don't know if you are or not)
Hope this helps
Hi there,
Hope this helps
I suspect what you actually mean is. Dynamic DNS.
Totally different to a dynamic IP.
Besides, it's the Router that needs to be checked more than the DVR
Sorry clearly a misunderstanding, I am not talking about the router, i am suggesting that Jazz should research that with his standard home broadband the dvr has a supported DDNS avoiding the need for external tracking websites.
Hi there,
Hope this helps
Cheers for the reply.
I know a lot about I.T So am fine with that part.
Already have a dns setup to remote access other hardware.
Just the cctv cameras I'm confused about.
Just don't want to spend money and end up with a poor product.
As there's no samples of the video quality only have the reviews to go on.
Any other cameras out there that will be suitable?
Minimum 700line and preferably dome style for the discreet look.
Jaspal
Hi there,
The cameras we use are trade only and i don't know of any other company that provide them. You could alway's pop into your local ADI Global Branch and see whats on offer. Check that the cameras you purchase do not have thumb screws to tighten, you don't want to make it easy for someone to change there positioning. My local branch has cameras on display showing you the image and giving you an idea on quality. Also try you tube to see if suppliers are showing the quality of the cameras.
Hope this helps
Hi there,
Hope this helps
And when the branch manager tell him to FCK off, trade only?
Jaspal
Just give cctvdirect a ring. Their kit is usually pretty good. You will be able to describe your requirements fully and they can then advise you better.
They're a reputable company.
Like i said.
You do all that with the router.
we use cctvdirect for most of our cctv kit and i can reccomend them fully!
the dvr`s we use arew the XDH ones
very good and reliable
also we use there cameras as well, all good kit and reliable with good image and IR
Oasis
Ok thanks will probably go with them then.
What's a good camera for above the front door?
As don't want the ir to blind the camera
All depends on distance, ambient light etc etc.
Like i said, speak to cctvdirect and tell them your requirements, they'll advise accordingly.
What is good for one location/environment may be pants for elsewhere.
Ok il see what they say,
For the connections for the camera, What product do i need to enclose the connectors outdoors?
Im after something discreet, iv seen some setup that have a waterproof box next to the camera. Is this the only solution?
