Hi folks.
Same old question - different make.
i have an old hob that is wired into a built in oven which then is wired into the switched cooker circuit on the wall that has a 40amp fuse in the cirtiutbreaker cupboard.
My new CDA oven and hob look like they do not connect to each other in the same way. Can i put both sets of wires into the same cooker point on the wall? The oven is 1.68kw and the hob is 6kw.
Yor help would be appreciated very much.
jase
jase
