I nearly posted this is a reply in another thread where the issue came up, but decided to split it off instead of de-railing the thread.
We all know of the requirement in 553.1.201 for socket outlets in household and similar premises to be shuttered, so would seemingly preclude BS4343 type connectors (although at least one well known publication appears to take the view that they can be installed outside of the dwelling itself and implies that within a shed would not fall under this, which seems to be stretching it a bit)
Personally I would have no issue with an interlocked type ceefrom socket installed domestically, as while not meeting the wording of the regs, does I feel, meet the spirit of what they are seeking to acheive, e.g. protection against kids sticking mother's best kitchen sisscors in L&N and having it go pop! Especially as BS7671 later adopted the same solution in section 708 to deal with the same issue in a different location. Now technically speaking, one ought to declare it as a deviation, I suppose, but I shouldn't imagine many do.
Back to the original regulation, the 'or similar premises is rather wishy washy wording, I wouldn't say a primary school classroom is a similar premises, but clearly the same issue applies here, so its cleary intended to apply here, but you kind of have to look at the reasoning behind the reg, rather than simply its wording to see that, should we include hotels in the scope? Likely the answer would be yes to the rooms and suites, but not to the swimming pool plant room (unshuttered sockets probably low down on the list of hazards kids could find in there!)
