Do you mean can you fit a spot bar with 6 spots to where there used to be a single fitting? if so, the answer is yes. If not, then you might need to be a bit more descriptive
Again, one could be neutral, one could be switched live. It depends how it's wired and how it was connected before. Just because the cable is black, doesn't mean it's neutral
