I have a lot of lights in the ceiling (low voltage, 50 Watt). The other side of the ceiling is in the loft itself.
So to allow for the heat of the light to disperse at the rear of the light, I have cleared for each light, an area of loft insulation material so that the light is clear.
However, with the shere amounts of lights in the various rooms in the ceilings, it means that probably half the loft has no insulation material between the joists now.
Is this the correct way to do it, or can anyone recommend a proper way of dealing with this?
Thanks for reading.
Thanks for reading.
