Hi Guys
Recently wired a ceiling rose in a new (old) house. Although the lights are now acting kinda screwy. When the newly fitted light is switched on there are no problems but when its off and the light in the bathroom (on the same loop) is turned on the newly fitted light glows dimly.....if that is then turned on the bathroom light will go out. Also I have noticed the energy saving bulb on the landing (also on same loop) is flickering a little...I imagine it would also glow dimly like the other if it was a normal bulb.
The newly fitted light does have two switches..one pull switch above the bed and another on the wall. Not sure if this is causing problems.
All i have touched is the wiring on the ceiling rose and everything was fine before. i've checked and double checked the wiring on the rose and i cant see anything obvious. Any ideas?
Maybe i disturbed some wiring when i unscrewed the old ceiling rose.
