My daughter snapped the cord on the switch, bought a new switch,but im puzzled, on the original this only one feed red goes to cond black to a1, question is what wires go where.on the new swith is supply and load.
b&q sold out of the cheaper ones, had no choice but to spend the £10 it was either that or let the lights bur bathroom all night, thanks for your help.
Put a weak link in the cord just below the switch. So the next time somone does a Tarzan swing the weak link snaps instead of the cord being torn out of the switcjh
I wish, last week a 25p bracket rusted away and dropped the float switch into the bottom of the sewage tank. The pump then ran continuously until the tank was dry. With no liquid to lubricat the metal to rubber pumping cavity the rubber wore away. The "perfume" of stripping that pump down lingers still. But Mono Pumps parts service identified the replacement part and had it on over night delivery that day,
So another tip is routine inspection should be carried out.......
