celcon thermolite blocks
24 Apr 2006
Gwent
Hello,I would be grateful for some pointers.Can anyone tell me if the celcon thermolite blocks are ok to use under strctural beams.I have two rsj beams (3m span)carrying the upstairs both skins on the side wall of the new ext ,one end of these beams will sit on a piller and the other will sit on another rsj on the internal skin that spans a window.The QUESTION IS...
Will it be ok to use the celcon blocks on the inside wall around the window bearing in mind that these are going to take the weight of the rsj beams .I have had struct calcs done but they did not mention if the celcon blocks were ok to use or that it would have to be normal breeze blocks
Thanks for any info :?:
Are there padstones under the beams where they meet the blockwork? (padstones distribute the load so that the weak blockwork can take it)
If its just picking up the wall load it shouldnt be a problem. If the engineers happy i wouldnt worry its what you employ him for, to take responsibility for the structure.
