Center RF thermostat intermittent
Discussion in 'Plumbing and Central Heating' started by chris1982, 10 Feb 2021.
  1. chris1982
    chris1982
    16 Nov 2013
    476
    Thanks Received:
    43
    Kent
    Country:
    A year ago alongside a new combi boiler we got a new room thermostat/timer, Center RF 340017, which I believe is a rebranded Honeywell. Sometimes when pressing a button on it (e.g. to manually change the temperature), the display switches off and after a few seconds asks to set the time, essentially as if I had removed the batteries. This morning, even worse, it did this without being disturbed, which is a real issue as it doesn't seem to call for heat until you confirmed the date.
    I tried new batteries but that didn't seem to fix the intermittent issue (when pressing buttons at least). Any other ideas?
    And if it gives up the ghost, is it possible to manually call for heat from the receiver at the boiler end (the receiver has a button but its functions are not explained in the manual)?
    Thanks.
  2. Sponsored Links
  3. polesapart
    polesapart
    27 May 2011
    1,393
    Thanks Received:
    366
    Country:
    Yes
    There's an overide button on the receiver which will give you the same steady indicator light as when the stat is calling for heat.
    • Thanks Thanks x 2
  4. gas112
    gas112
    27 Oct 2009
    23,079
    Thanks Received:
    8,259
    Country:
    if its still under warranty get it changed they have had a few faulty ones doing this
    • Thanks Thanks x 2
    • Like Like x 1
  5. chris1982
    chris1982
    16 Nov 2013
    476
    Thanks Received:
    43
    Kent
    Country:
    I got it changed. Wolsey did say they had some faulty batches.
    Does it take time for the optimal stop function (I activated that function) on the replacement to learn, or should it work right away (it didn't switch off early last night, as I had expected given the old one's behaviour)?
  6. Shed Steve
    Shed Steve
    3 Jan 2011
    146
    Thanks Received:
    2
    Norfolk
    Country:
    I had a 340017 installed with a new combi Baxi 830 last November, and on 4 occasions now, it has asked for the Date to be input again. I shall call my heating engineer tomorrow. I am presuming, that the fixed Receiver has to be replaced as well as the mobile Thermostat. I'm glad I checked on here.
  7. gas112
    gas112
    27 Oct 2009
    23,079
    Thanks Received:
    8,259
    Country:
    2 min job the fixed reciever just pops off leaving back housing and the wiring new one just pushes back on
  8. Shed Steve
    Shed Steve
    3 Jan 2011
    146
    Thanks Received:
    2
    Norfolk
    Country:
    New 340017 now installed a week, seems OK.
    • Like Like x 1
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
