Hi, can anybody help. Central heating system was installed over 18 months ago. It was installed in a refurbished project, and was working at the time of installtion, and then not used any further, however, i have just tried testing it and to no avail. all rads are full. no air present, even aired how water cylinder. Boiler fires but goes off after a minute. room thermastat turned to maximum. Programmer seems to work ok, selects central heating and hw and clicks ok to on. Water from on top end of boiler is hot, suppose this is the flow, the return is cold. Pump is hot, but water from both sides of pipe are cool. Doesnt seem to have any noise from it, i have tried tapping with hammer. 3 way valve lever moves very freeely down and reamins there, water to all pipes still cool from this. 1st nearest rad is warm, but nothing else. Hot water is tepid, set at 75c. I have opened screw on front of pump and a small amount of water leaked out. Does anybody have a clue what is wrong with it, as i said boiler keeps shutting down. everthing was new, thanks
