I have a Baxi 100 Combination Boiler. When the central heating is in the OFF position, and all the radiators are closed, no hot water comes out of the tap, it runs cold. There are the normal green lights on both the burn and the tap lights, and then on the burn light you get a red flash and then the burn light goes off. What should also be noted, if I open even one radiator and the central heating is in the OFF position as stated above, the radiators still heat up and the burn is fine. So the two questions are:-
Why is the water not heating?
and
Why is the central heating working in the off position?
Thanks a lot and any advice would be most welcome
and
