Central heating comes on when I run a bath
22 Dec 2007
Suffolk
I moved into my (privately rented, gas-fired CH) flat 2 years ago. For some reason, whenever I run a bath, the shower, or the washing machine, the central heating comes on. Apparently without activating the boiler.
It's not a problem particularly, although it's a bit annoying in the summer, to have all that superfluous heat belting out. I'm just baffled as to why it should be set up like this (I understand the last tenant installed the shower over the bath himself, so I'm presuming it's down to him), and hoping someone can shed light on the puzzle.
Is it common practice? Is it something I should be concerned about?
Geometer
This is bizarre and doesn't really make sense!
By "central heating comes on", do you mean that the radiators get warm?
Do you have a hot water cylinder (big cylindrical tank with foam insulation) or is it a combi boiler (no hot water cylinder, boiler fires up as soon as you turn hot taps on).
Most modern washing machines are cold-fill only, in other words, are only connected to a cold water supply via a blue hose, so operating the washing machine shouldn't affect your hot water supply at all.
From the info you've given us I suspect that you have a combi boiler and that it makes the radiators feel slightly warm after you've run a hot tap, because combis often use the radiators to cool down the primary heat exchanger when the hot water demand stops. When you switch the hot taps off, can you still hear the boiler's pump running for a minute or so afterwards?
Tell us more!
Is it? Quite common in my experience.
But the OP never said he had a modern washing machine.
I agree.
I disagree.
OP ....Your diverter valve is almost certainly passing.
Yes, that's a more accurate description. Only, they don't get warm, they get hot - as hot as they would be if the CH was on.
Combi. Worcester 24CDi.
Yes, cold-fill WM, Zanussi Aqualux.
This is the odd thing - the rads only heat up when the WM, the shower, or the hot tap to the bath are used, not the hot taps to kitchen or bathroom sinks; and the boiler doesn't come on at all.
I don't know what that means, but it doesn't sound good :shock:
Is this something I should bring to the attention of my landlord? Is it an easy fix?
Thanks for the replies
Yep..tell the landlord the boiler is faulty.
Whoever comes to fix won't be very pleased when they see which boiler you have.
The diverter on a 24 CDi is one of the worst jobs in boiler repair land :D
