Hi
Just moved into a new house, heating control would appear to be unique, currently installed as follows:
Open vent system, RWB2 controller, no room stat, single zone valve in CH loop and a cyl stat !!! all wiring stuffed into electrical junction box and 240 v to RWB2.
Assume this setup needs an addtional Zone valve in the HW loop, also wiring needs correcting to include; fuse spur and wiring centre, room stat in CH circuit and cyl stat in HW circuit.
Also it appear that there is a by pass loop on the HW feed to the cylinder, should this loop have an automatic bypass valve fitted?
Hopefully this whole setup will junked in about 12 to 18 months, house extension and new boiler pending.
I would be grateful for your comments.
Kind Regards
Rob
[/img]
Kind Regards
Rob
[/img]
