Last year I had our oil fired central heating boiler replaced with a Grant outdoor type. As it lives outdoors this boiler has a built in froststat to protect it in cold conditions. I suppose Grant err on the safe side & I found that the boiler ran whenever it was about 5deg C or colder - last year this was almost continuously from October to March.
The problem is that as far as I can see from the wiring diagrams, electrically the froststat calling for heat has exactly the same effect as the programmer and roomstat calling for heat i.e. whenever it's cold ouotdoors the whole central heating system operates.
This means that the house is lovely & warm all the time (even when nobody is here or when I'm in bed) but my oil consumption more than doubled !
I am told that it is possible to install a short circuit which is opened up by an actuated valve. In this way when the room stat calls for heat the circuit operates normally but when it's only the boiler's frost stat (ie if I'm on 2 weeks ski-ing holiday) the water is circulated around a much shorter loop & doesn't heat the whole house.
Is anybody able to advise me how this can be done or where I can find somebody that can design it for me to wire up as I can find nobody locally that knows the answer.
