Hi all,
Wonder if someone can advise on a plumbing problem on a new rad?
Background:
4 x rads upstairs fine
1 x rad downstairs - works, but takes a while to heat up.
There was 2nd rad downstairs on the dividing wall between kitchen and dining room, but took the wall out and removed the rad a couple of years ago.
Due to the one rad downstairs taking so long to heat up, I thought I would fit another one to get me through this winter.
The guys who took the wall out a couple of years ago re-routed the pipework over the dividing area between kitchen and dining room and left the pipes capped off at low level ready for when a new rad was to go in.
So, drained down the central heating, put the new rad in, re-filled the central heating. Bled the four rads upstairs, then the two downstairs. The four rads upstairs are working fine, but neither of the two downstairs are heating up.
After lots of head scratching, I have open up the plasterboard when the guys who took the wall down and boxed in the new pipework for the new rad.
In the pic below I have circled two sections which I believe is what they fitted.
The two areas circled in RED were hot to the touch, but within a foot further along to the left were cold.
Bleeding the radiator out of the tiny bleed hole for about 20 minutes, pulled the hot water through the feed pipe and eventually the downstairs rad started to heat up, around the edges, but an hour later, no additional heat, and the water coming from the bleed hole was hot.
Nothing ever seemed to go back to the return as this pip remained cold.
Closing the bleed hole on the rad, caused it to cool down again, and eventually the feed pipe in the ceiling cooled also.
In summary:
1. The feed and return in the ceiling both start to cool after the angled sections (I have determined which is feed/return purely from how the pipe heated up when bleeding)
2. Bleeding the rad pulls hot water through the feed
3. How the rad is plumbed in below - I didn't know which was the feed/return at the time, but the valves are bi-directional so don't think this should be an issue
4. When bleed is closed, rads and pipes cool down
5. Pic below shows area on rad which heats up when bleeding
6. Other rad which used to work isn't coming on at all now
Any advice appreciated!
Background:
In summary:
